Nou ik kwam vandaag dit tegen op een site. Je kunt nu zelf je olie interval resetten of rem-lampje. Kan handig zijn als je zelf je olie ververst of remmen verwisseld. Heb het zelf niet geprobeerd maar, wie er wat aan heeft veel plezier ermee, p.s. is wel in het engels, maar dat mag geen probleem zijn.
Oil Service Interval Reset - 2007+ R56 & 2008+ R55
To Reset Service Indicators such as the Oil Service Interval, or the Brake Wear Light, perform the following steps:
To enter the service Menu:
Insert Key
Do not press clutch / brake
Press Start button
Wait until the Car / revelant Service symbol disappears on the Rev counter display
Immediately after the symbol goes out - Press and hold Both buttons on the Rev Counter
Continue to hold - the system will run a dash light check
Continue to hold
Display will then show VIN / Menu, - continue to hold through this until the time Reappears on the display.
Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button)
After another second of 2 the display will show the Front Brake Symbol You Are
Now in the Service Menu
Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Oil Reset or Rear Brakes
To Reset the warning indicator light - Press & Hold the BC Button at the revelant symbol until RESET appears - then press and hold again until the process is complete.
Turn Off and On the Ignition again - Warning should now have gone!
Good Luck !
Succes,
Jack
