Batje MCCS......
louisvdd76
De Scheurende Rechter
Re: Batje MCCS, Remblokken hulp gevraagd :( p38
29 sep 2015, 17:47
Batje schreef:f**k me..... Die carbotech dingen zijn van goud gemaakt of wat.... 376 pond... Ik vind het nogal 500+ euro voor remblokken.....
Als je een GB op start hiervoor echt wel minder... (XP10 voor Cooper S of R56 JCW remmen) :()
Manick
Sponsor
29 sep 2015, 17:50
En wat als je nou eens TRW of Bosch neemt, kijken hoe langs dat mee gaat, kost mess 100 euro en is een goeie vervangen van OEM
Batje
29 sep 2015, 18:00
Ja oke maar dan nog in combi met de achter blokken etc wordt t dan nog steeds duurder dan de Tarox.
En mij is de XP8 aanbevolen, zie hier de uitleg. Dus weet niet of de XP10 voor nu zo handig is..
Hi,
Ok no worries, on the rears its more tricky as the Mini does not have much weight over the rear wheels so we cannot go too strong on rear pad compound, as a general guide we would go 1 compound lower on rear so with XP8 front we go AX6 rear which should work well, rear pads are pretty expensive though so it maybe some more yellowstuff on rear works out better for you and once you get a good pad in front it should cope ok, i guess it depends how much you want to spend.
It maybe you have been getting brakes hot before but at places like the ring the brakes can cool right down on the long straights and this is when XP10 can have a problem, when it starts to cool it goes a little wooden feeling and brake force reduces, not so much of a problem on a big heavy car with heaps of power, but on a small lightish car like a mini it can cause problems with this cooling period, it would probably be ok on smaller circuits but i think at the ring you may have problem
As i mentioned previously if you did our pads in front you could most likely get away with running a stock rear pads or ebc yellow on rear to get your spending down, if you had XP8 in the front which does most of the work it would still work very well, normally on Minis unless full track spec we run stock rear pads or something mild like ds2500 or ebc etc.
Waarom? Omdat het kan, daarom
BurnoutBram
29 sep 2015, 18:25
Wel leuk dat ze gewoon Yellowstuff achter aanraden ipv hun product aan te smeren!
Maar heb je gezegd dat je een diffuser hebt en dus meer downforce hebt?
Batje
29 sep 2015, 19:29
Nee want dan wordt t nog duurder als ze dat weten :S
29 sep 2015, 23:55
Hahaha
Ik zou voor een goedkope (oem vervangings)blokken achter gaan en die XP8 op de vooras
30 sep 2015, 07:47
BurnoutBram schreef: Maar heb je gezegd dat je een diffuser hebt en dus meer downforce hebt?
:lachuh :lachuh :lachuh
Maar idd tof dat ze eerlijk zijn over wat te nemen!
Weet je gelijk wat te doen nu toch ;)
Batje
30 sep 2015, 08:32
Klopt..huis of vriendin verkopen...
30 sep 2015, 09:02
en Pagid nog een optie misschien?
30 sep 2015, 09:05
Zijn ook niet echt goedkoop trouwens, maar remmen wel goed.
30 sep 2015, 09:10
Ik heb nu Pagid in de AP-remklauwen zitten. Nog nooit een hint van fading gehad! Remmen zijn ook wel groter, maar toch...
Ik vind ze wel veel stoffen, maar dat boeit Bart toch niets :mrgreen:
30 sep 2015, 09:11
Heb je de blauwe blokken van Pagid?
Batje
30 sep 2015, 09:44
Meh alleen voor de jcw klauwen...
30 sep 2015, 09:45
Eigenlijk is de oplossing dus heel simpel....;)
30 sep 2015, 09:46
frankie schreef:Heb je de blauwe blokken van Pagid?
De blokken zijn geel
