Electric Supercharger
WoK
17 jan 2011, 13:50
Aan de ene kant kan ik geloven dat het vast wel iets zou moeten helpen...
maar aan de andere kant vind ik het maar een vreemde gewaarwording...
MimoUSA Electric Supercharger
$296.65 $399.00
You save 26%
* Produces 15 - 25 horsepower increase.
* Generates 250CFM of forced air.
* Universal Bolt-on, installs on any short ram or cold air intake.
* K&N Filter included.
* Installation instructions and all necessary installation hardware included.
* Pipes are not included, the car must be equipped either a short ram or cold air intake. (If you do not have an intake we would recommend the Weapon R Secret Weapon)
* Universal application. (Unit will replace your aftermarket air intake filter, please check to see if there is enough room by your air intake filter to install this unit.)
If you need a boost and can't afford a real turbo or supercharger conversion, this product is for you. The Electric Supercharger is an adapter to either your short ram or cold air intake. It will work on absolutely any air intake brand including AEM, Injen, MimoUSA, Weapon R, Fujita etc. Simply remove your current air filter and put the Electric Supercharger as a replacement, it's that simple.
The electric supercharger is operated on a 12-volt source. This means you can connect the electric supercharger to your battery to get the power. It uses 2.2 amps from your alternator when turned on and doesn't affect your car performance or battery drain. The Electric Supercharger is connected to a switch inside the car. Whenever you need more power you simply flip the electric supercharger switch and fly away. The electric supercharger produces 250CFM of forced air into your manifold and it is very quiet under the hood when the electric supercharger is turned on. In fact it has a nice aggressive sound, making it seem like you got something bigger then what you actually have under the hood.
A stock turbo from an Audi 1.8T produces 400CFM. Adding the electric supercharger will produce more then half of the power than a stock Audi 1.8T turbo would. There is no need to do any modifications to your engine at all. 250CFM of forced air can also be compared to a 15-25 shot of Nitrous.
The electric supercharger is made out of the finest parts and a certified K&N Filter with Lifetime warranty. Installing the electric supercharger is very simple, it should not take more then 15 minutes to install.
PK winst is overigens wel neetes veel voor een filtertje met attributen....
17 jan 2011, 14:53
Eigenlijk gewoon een fohn onder je motorkap :mrgreen:
die kan je ook bij de Hema vinden, voor een tientje :lol: :lol:
17 jan 2011, 15:44
Zal ook wel een geluid geven ofdat je een luchtbed aan het opblazen bent onder je motorkap. :mrgreen:
WoK
17 jan 2011, 16:19
duur luchtbedje :P
Geef de KN filter zelf al niet vermogenswinst als aangegeven? ;)
17 jan 2011, 18:43
Dit ding bouwt totaal geen druk op en is dus ook totale onzin.
Ongeveer 0,1 pk vermogensverlies omdat het stroom verbruikt.
Is op andere autofora al uitvoerig besproken.
